Activity › Forums › Adobe Premiere Pro › audio sounds like its skipping in CS5.5
  • audio sounds like its skipping in CS5.5
    Posted by Paul Watkins on July 18, 2011 at 6:30 pm
    working with cs5.5, I loaded in clips from HD XDCAM using cs5.5 and it is mostly all good, however, some of the clips have TECHNO music in them and it seems like it starts to skip inthe audio track, Video is fine, (original is fine, also). Nothing I can do will fix it except top convert clip to .mov fil and put on timeline and all is well? Suggestions. Cs5.5 is set up properly and the clips were imported using CS5.5? HELP!
    Paul Watkins replied 15 years, 2 months ago 3 Members · 6 Replies
  • Dan Daube
    July 18, 2011 at 8:07 pm
    Are you using a Kona or BMD card?
    Latest drivers might be an issue? Be sure for Kona anyways it’s 9.0.1
    check this previous post too: https://bit.ly/oDsFrb
    Dan Daube
    Director-Editorial Turner Studios Atlanta
    Manager Multiple Systems-FCP 7.0.1 AJA Kona
  • Paul Watkins
    July 18, 2011 at 9:42 pm
    what is weird is that I can see it on the timeline that way too. Happenbs with certian clips. I am using a mac laptop. nothing else other than a matrox le w/map is attached with nothing attached.
  • Dan Daube
    July 18, 2011 at 10:19 pm
    If you are actually seeing breaks that’s not the stutter issue we’ve “heard” about that’s been related to cards; that would be something else indeed.
    Did you do the sequence set-up by dragging one of those clips to create it? I’m not familiar with Matrox, but I’d check drivers and be sure that there isn’t a similar issue with set-up inside Premiere and in your overall settings.
    Dan Daube
  • Paul Watkins
    July 18, 2011 at 10:43 pm
    I did it all, set it up, drag and let it do it’s thing. The wierd part is I can see it where it will skip. strange eh’
    pw
  • Jon Barrie
    July 18, 2011 at 11:09 pm
    Sounds like an issue with conforming the file. Cleaning the cache would fix it if that is the problem. When importing footage allow it to finish conforming before using it (adding it to the timeline) to avoid this type of issue again.
    JB
    Jon Barrie
    aJBprods
    Jon’s YouTube Tutorial Page
    follow Jon with twitter
  • Paul Watkins
    July 18, 2011 at 11:57 pm
    TO Jon,
    makes since! I will try it on next HDXDCAM Project. and all of them.
    pw
