Audio sounds (and looks) fine in FCPX but clips after export
Hi all. I’m a newbie to this forum but am hoping you can help me out. I’m working with a bit of audio and video in Final Cut Pro X. The vocals had a bit of noise so I cleaned them up, using ‘Background noise removal’ found in Audio Enhancements. I also applied a Logic compressor to the track. It sounds perfect and, from watching the waveforms/audio levels, everything sits -4db, no peaks.
The strangest thing happens when I export though, for some reason the audio starts clipping, popping and clicking. This isn’t in the FCPX edit though, which plays through fine. If I bring the track into Logic you can see some clipping occur looking at the waveforms. Have any of you had this experience or know how to solve it? I just want the audio heard in FCPX to be in the finished product too.
Thanks in advance, Chris
