Activity Forums Apple Final Cut Pro Legacy Audio snycing issues in FCP 7 (24P)
  • Audio snycing issues in FCP 7 (24P)
    Posted by Richard Lipman on February 1, 2014 at 3:38 pm
    The audio slowly drifts out of sync. Additionally the file lengths changes length after importing into FCP. Any solutions? Thank you.
    I am using 24p sequences as well as 24P WAVE audio. The original media including pro res 422 hq is 24P
    Are you importing them back into the same session, or did you start a new one? – I have done both, still no difference . Both sequences , 24p, 48 htz, 24 bit
    I have transferred all to AIFF – FCP does not recommend mp3 – AIFF no difference in file length
    Richard Lipman replied 12 years, 7 months ago 2 Members · 2 Replies
  • Dino Vince
    February 4, 2014 at 6:07 pm
    Is there a way to ‘audio lock’ your source footage before bringing into FCP? This used to be an issue with DV vs. DVCAM formats.
  • Richard Lipman
    February 4, 2014 at 6:22 pm
    thanks issue solved
    it was a sequence issue, right settings were neeeded plus copy and reimported audio file and restarted fcp 7
