Activity › Forums › Apple Final Cut Pro Legacy › Audio Slowing Down in FCP7
  • Audio Slowing Down in FCP7
    Posted by Nathan Matta on November 22, 2013 at 9:02 pm
    I’ve searched through this forum before and I cannot find a fix for this issue. Most of the time FCP 7 works fine. However, recently projects keep playing back with half speed audio and bringing up a rendering error, and the messed up audio is still there when I export. I’ve deleted my user preferences and have even uninstalled and reinstalled FCP 7. Nothing works completely, and I end up running into the same issue.
    Thanks for any help!
    Nathan Matta replied 12 years, 10 months ago 2 Members · 4 Replies
  • Nathan Matta
    November 22, 2013 at 9:29 pm
    It keeps bringing up the Dropped Frames Warning when I try playing anything back.
    Sometimes the audio is slow, sometimes it’s gone. Other times, it’s fine in one ear and slow in the other ear. I am completely at a loss!
  • Shane Ross
    November 22, 2013 at 11:54 pm
    What is the format of the footage you are editing with? What are your sequence settings?
    Shane
    Little Frog Post
  • Nathan Matta
    November 25, 2013 at 1:46 pm
    The sequence settings are as follows.
    Video:
    XDCAM HD 1080p24 (35 mb/s VBR)
    Audio:
    48 kHz 16-bit
  • Nathan Matta
    November 25, 2013 at 2:26 pm
    I feel sheepish! I just noticed that the WAV music that I am using is 44.1 mHz and the sequence is at 48 mHz. When I changed the sequence settings to 44.1, things started working fine. I hope that was the issue!
    Thanks for your help.
