Activity › Forums › Apple Final Cut Pro Legacy › Audio Slip with 24p mode
  • Audio Slip with 24p mode
    Posted by Martin Sterling on September 6, 2005 at 8:51 pm
    I shot some footage with my panasonic dvx100a camera on scene file 5 which is normal 24p and digitized it into FCP4.5 us DV NTSC 48K settings. Im getting a big audio lag from the start of the tape what am I doin wrong?
    Thaxter Clavemarlton replied 21 years ago 2 Members · 2 Replies
  • Martin Sterling
    September 6, 2005 at 9:00 pm
    The Sync seems to be finen smaller clips, but not in larger ones. My original capture was 1hr which was out of sync. I did a 3 min clip, it was fine. How do I fix that or can it be fixed. And What is the max length I should be capturing at
  • Thaxter Clavemarlton
    September 6, 2005 at 9:50 pm
    “Sync-slippage” can happen during some longer captures.
    To avoid it, break your captures into sections no longer than about 10 minutes each.
    You can then “reconstruct” the full tape’s recording (or any longer takes) quickly if you need to.
    Mark (and log) your first clip to End (Out-point) about 10 minutes or less from its In-point.
    Continue to mark (and log) your clips this way throughout the rest of the tape.
    Just make sure the In-points of the subsequent clips are EXACTLY ONE FRAME LATER than the Out-points of the previous clips.
    You can do all this while actually scanning the tape(s) or just by inputting arbitrary TC numbers, logging them… then use Batch Capture to bring in all of your clips.
    Its very easy to then “reconstruct” the shorter clips back to any “continuous” length you want on the timeline by just “clicking” them on in order.
    EVEN FASTER… select ALL successive clips at once in the browser (with the browser column-order set to “Media Start” highlight all clips) and drop them, all at once, on the timeline… they’ll all pop up in continuous order.
