Activity Forums Apple Final Cut Pro Legacy Audio slip for playback?
  • Audio slip for playback?
    Posted by Bill Thomas on March 20, 2007 at 12:17 am
    I heard that FCP can slip the audio during playback to correct for bad sync. Is this possible when just playing back (as opposed to recording to tape)?
    My problem: I’m recording straight from FCP to a set-top DVD burner and I always have a little bit of a sync issue – especially noticeable during talking heads. Is there a feature in FCP that I can slip audio on a whole project, instead of adjusting each and every audio track?
    Thanks in advance for the help,
    Bill
    Steve Braker replied 19 years, 6 months ago 3 Members · 2 Replies
  • Steven Lambion
    March 20, 2007 at 1:26 am
    There is a way to offset playback, but I don’t know how to offset just audio.
    Heres my solution: take your edited sequence and put it into a new one then all you have to do is offset one track and with out harming your editing one. I use the ‘+’ and ‘-‘ keys to move the clip by frames, it’s easier and more precise than the mouse.
    Video Specialist
    Apple Developer
    Owner of GranitWorks
  • Steve Braker
    March 20, 2007 at 1:36 am
    Caution: make sure there really is a problem in the sync relationship of the files before you end up “fixing” something thast ain’t broke. Your sync problem could be in playback, in the monitoriing system(s) you’re using…
    Easiest way to check the actual sync is to find a single sync point in audio and video that you can check by scrubbing frames. 400 pound weight dropping on studio floor, pencil eraer thwacking desk, etc. Identify the frame and see where the sound falls in the waveform.
