Activity › Forums › DVD Authoring › audio skips at end of DVD playback
  • audio skips at end of DVD playback
    Posted by Jack Entonces on April 30, 2006 at 11:37 am
    I’ve finished a project on Avid Xpres DV 3.0.
    On my timeline everything plays back perfectly,
    but when I burn the timeline to a DVD (using the proper procedures, I’ve done it before with success),
    when I play back the DVD, at the end,
    the audio, which is music, stutters and skips.
    I’ve tried burning several times and keep coming up with
    the same stutter at end of audio track.
    Any ideas or suggestions on what is causing this,
    and how to fix it?
    thanks to all
    Alex Alexzander replied 20 years, 5 months ago 2 Members · 1 Reply
  • Alex Alexzander
    April 30, 2006 at 3:42 pm
    What I do is I send the timeline to an MPEG2 compression application. From there, I author a simple DVD. Granted your way is faster, but it is only faster if it works the first time.
    Check out this low-cost encoder:
    https://www.visiblelight.com/mall/productview.aspx?sku=cceb
    If you combine this with something like ReelDVD or DVDit, you can create a simple DVD, very quickly, and your skipping troubles should go away. So long as you keep the bit-rates reasonable. Say around 7.5 Mb.
    -Alex Alexzander
