Activity › Forums › Apple Final Cut Pro Legacy › Audio Skip Out At End
Posted by Kyler Boudreau on March 19, 2010 at 4:08 pmSpecs: Snow Leopard / FCP7 / MacPro / Quicktime Player 10.0
Problem: imported MP3 and when positioned in timeline in one spot the MP3 looses sound for one frame. If I take it out and replace in timeline, does the same thing. *Note: Does not skip in clip monitor.
Action: exported the MP3 as Apple Lossless via Compressor and made it a Quicktime. Imported and laid back in timeline. Still misses at the same spot. It is a music climax and right at the climax it goes dead for a frame or two. Weird.
Lowered volume in timeline to see if it was peaking – nope. still does it. ARGH.
_______________________
kyler boudreau
http://www.theatereleven.com
ph.310.425.2231John Fishback replied 16 years, 2 months ago 2 Members · 8 Replies -
John Fishback
March 19, 2010 at 4:55 pmAudio should always be PCM (aiff) 48k 16/24 bit. Using QT Player, VLC Player or other external player, does the audio play OK?
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 3 (FCP 7.0.1, Motion 4.0.1, Comp 3.5.1, DVDSP 4.2.2, Color 1.5.1)Pro Tools HD w SYNC IO & 192 Digital I/O, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
Kyler Boudreau
March 19, 2010 at 5:05 pmYeah, it plays fine in the clip monitor. That’s the weird thing. This is I think 23.976 footage from a panny HVX200. not sure if i need to do something special on audio import? I know in Avid I used to have to set audio import by project, but Avid always made its own MXF or OMF files. Final Cut doesn’t seem to do that?
kyler boudreau
ph.310.425.2231 -
John Fishback
March 19, 2010 at 5:23 pmFrame rate should not affect this. Try trashing your audio renders and re-rendering. If you have many audio tracks then an Audio Mixdown would be in order: Sequence Menu > Render Only > Mixdown. It’s worth trying it even if you don’t have a lot of tracks.
John
Kyler Boudreau
March 19, 2010 at 5:32 pmThanks John – how do you trash audio renders? Sorry….I’m new to Final Cut. In Avid I didn’t have to render audio when I put it in the timeline. But I’m assuming that is because on import it was converted to an aiff while Final Cut leaves it as MP3?
kyler boudreau
ph.310.425.2231 -
Kyler Boudreau
March 19, 2010 at 5:36 pmFound the render files and deleted them. Rendered again. Same problem. Did a mix down….same issue. Really strange!
kyler boudreau
ph.310.425.2231 -
John Fishback
March 19, 2010 at 5:51 pmJust to be sure, you need to change the mp3 outside of FCP. You can use QT Pro, MPEG Streamclip and other programs to do that. FCP rendering it internally won’t do it right. The only other thing I can think of is if the gain exceeds 0 and the audio clips, that could cause a dropout effect.
Have you trashed prefs and repaired permissions? If not, do that, too. There’s a tutorial about how to do that on the Cow.
John
Kyler Boudreau
March 19, 2010 at 8:04 pmThat was it John…i brought the MP3 straight into Compressor, turned it into an aiff and imported that. Voila! THANKS!!!
kyler boudreau
ph.310.425.2231 -
John Fishback
March 19, 2010 at 8:14 pmI’m glad it worked.
John
