Activity Forums Apple Final Cut Pro Legacy Audio Separate channels output????
  • Audio Separate channels output????
    Posted by Ed Stevens on August 16, 2005 at 5:28 pm
    My SYSTEM
    MAC dual G5 2.5 gig. 4.5 gb RAM. OS 10.3.8
    Blackmagic Decklink Extreme card v4.8b
    FCP 4.5 production Suite
    500GB G-Raid Firewire800
    Decks = Beta-SP, DVCpro, DigiBeta.
    Audio Mix = Mackie 1604 VLZpro
    I am trying to get 2 separate channels outputto tape. I have audio on Ch 1a and 2a . 1a is VO and 2a is the B/roll sound.
    How can I get the them separated?
    Thanks in advance
    ED
    Ed Stevens replied 21 years, 1 month ago 3 Members · 5 Replies
  • Rick Dolishny
    August 16, 2005 at 5:33 pm
    Unlink the stereo pair if they are joined (if you drag one volume and they both move they are paired)
    Select track one and press CTRL ,
    Select track two and press CTRL /
    They are now split off to either speaker.
    – R
  • Ed Stevens
    August 16, 2005 at 5:53 pm
    Thanks for the tip. How do I select the entire track line. I am only affecting a single clip.
    ED
  • Rick Dolishny
    August 16, 2005 at 6:45 pm
    Just click and drag to select all the tracks you wish to pan.
    – R
  • Michael Peele
    August 16, 2005 at 9:54 pm
    Don’t forget to pan your mackie left and right if you are going to beta – a lot of people leave the pan pot at center which will result in ch1 being audible on ch2 and vice-versa. Not an issue if you are dumping to DV via firewire or if your beta is wired directly to your dv deck with no mixer in between.
    Mike Peele
  • Ed Stevens
    August 17, 2005 at 2:59 pm
    MAny thanks for the advice and tips
    ED
