Activity › Forums › Apple Final Cut Pro Legacy › audio scrub in trim mode?
Posted by Peterson on March 3, 2006 at 11:04 pmNew to FCP, so thanks for help on a simple one: how do you select audio scrub while in trimming mode as I often use the single frame to ‘hear’ my way through a trim. Also, how to select which track to isolate in this unknown trim / scrub mode. I have looked through the manual and have not located this instruction.
peter
Curt Needs replied 11 years, 12 months ago 7 Members · 7 Replies -
Tanya Schneider
March 18, 2009 at 2:39 amHi Peter
I am just new to FCP and found your post about audio scrub in trim mode… did you ever find out how to do this?
Cheers
Tanya -
Vincent Bruzzese
August 18, 2009 at 5:28 amFCP does NOT scrub frame by frame in Trim mode.
Kinda hard to believe huh?
Guess they like it pro-sumer. -
David Battistella
August 18, 2009 at 1:54 pm[Vincent Bruzzese] “Kinda hard to believe huh?
Guess they like it pro-sumer. “Vincent,
There is no need for this kind of negativity. If you don’t like a feature in the software maybe ask a question, but this kind of post is not really helpful to anyone.
If you want to answer a question then just answer it. Nothing gets added with the rest of your opinion.
David
Peace
Check out my new web series.
https://www.ripperhockey.com -
Joshua Schwarz
July 12, 2010 at 3:36 pmi’m an avid editor making the transition. i have found that you can scrub in fcp trim mode if you have your user settings/editing set to “trim with sequence audio.”
i have a related question. rather the going to the trim window, i prefer to trim in the timeline using the “[” and “]” keys. it’s a bit faster. however, i haven’t found a way to enable audio scrubbing while trimming that way. does anyone have a technique for trimming in the timeline with audio scrubbing?
thanks,
josh
Mark Block
August 20, 2013 at 10:47 pmThis thread is years old now, but I just stumbled on it.
You can do Avid-style trimming with audio in the Tim Edit mode. Hold down the “K” key, then blip the “J” or “L” keys to trim back and forth while hearing one frame of audio at a time.
– Mark Block
Tanya Schneider
January 1, 2014 at 3:54 amThanks Mark! That’s awesome! I can’t believe I haven’t stumbled across this anywhere else!
Curt Needs
September 23, 2014 at 7:22 pmNot sure if this is what you mean, but I often am cutting interviews and need to merge the same word together or put two totally different thoughts together and make it sound like a single thought/sentence. The main way I do this is scrubbing frame by frame in the audio and making sure it plays smoothly from one clip to the next.
If you ever find that you accidentally turned this off, just press Shift-S to turn frame-by-frame audio scrubbing back on. At least on FCP7 this works. Not sure on X.
