Activity Forums Apple Final Cut Pro Legacy Audio sample Rates
  • Audio sample Rates
    Posted by Kevin Mcquade on July 25, 2007 at 7:46 pm
    I am trying to export a .wmv from FCP5. It tells me that I have multiple audio sample rates so I went through them all, making sure they all matched and I still get the same error. I have also opened other projects where I exported without any trouble with mixed sample rates and I received the same error. Any ideas?
    My Sequence is Blackmagic 10 bit with 48k sample rate. The music from cd’s is 44.1.
    Kevin Mcquade replied 19 years, 1 month ago 3 Members · 5 Replies
  • John Fishback
    July 25, 2007 at 7:53 pm
    FCP doesn’t like 44.1. Make sure you’ve rendered everything. You could also try exporting a QT first and then converting to wmv from that.
    John
    Dual 2.5 G5 4 gigs RAM OS 10.4.8 QT7.1.3
    Dual Cinema 23 Radeon 9800
    FCP Studio 5 (FCP5.1.2, DVDSP4.1.1, Comp2.3, STP1.1, Motion 2.1.2)
    Huge U-320R 1TB Raid 3 firmware ENG15.BIN
    ATTO UL4D driver 3.50
    AJA IO driver 2.1 firmware v23-28
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neuman U87s, Genelec Monitors, PrimaLT ISDN
  • Kevin Mcquade
    July 25, 2007 at 8:17 pm
    Tried that, oddly I got the same error. The only time I have a problem is when I try to export a .wmv
    I wouldn’t worry about it if clients had QT.
  • John Fishback
    July 25, 2007 at 8:58 pm
    What are you using to make the wmv?
    John
  • Jeremy Garchow
    July 25, 2007 at 9:03 pm
    This is a known bug the flip4mac (telestream) is aware of.
    https://www.flip4mac.com/knowledge/kb_0070.htm
  • Kevin Mcquade
    July 25, 2007 at 9:06 pm
    This is what I recieved from Flip 4 Mac. I was relived to find out I didn’t mess something up…
    That is a common problem we’ve been having with Quicktime 7.2. We have
    > confirmed that when encoding WMV files with uncompressed audio sources after
    > installing QT 7.2, you will receive a multiple sample rate error and the
    > encode will fail. This affects Flip4Mac WMV Studio, Studio Pro, Studio Pro HD
    > versions. We are working to resolve the issue as quickly as possible.
    > You might want to try the following steps as a temporary workaround:
    > 1. Open up the clip in QT Pro, iMovie or Final Cut Pro
    > 2. Export to Mpeg-4
    > 3. Click Options
    > 4. On the file format pull down select MP4
    > 5. On the video format pull down select Pass through if possible. Otherwise,
    > select H264.
    > 6. Then go to the audio tab, and change the output sample to 44.100
    > 7. Then save the file
    > This will make an MP4 file which will not recompress the video format more
    > than once with the audio sample rate changed to 44.100 which will allow the
    > file to be exported to WMV.
