Activity › Forums › Apple Final Cut Pro Legacy › Audio sample rate issues
  • Audio sample rate issues
    Posted by James Martin on November 16, 2007 at 12:27 pm
    I’m getting the multiple audio rates error when I try to export at anything apart from sequence settings or mpeg. I do have multiple audio rates in the timeline (some of the music is 44 rather than 48) but I thought that was why we rendered!
    I’ve tried replacing the audio with an aiff export – I’ve tried converting a DV PAL export using quicktime – I still get the same error message.
    I know flip-for-mac is often the culprit but the only time it has been involved was when I opened the compressed music files – could it be the problem or do I have another issue.
    I’m using FCP 5.1.4.
    Any help would be gratefully received as my deadline is blown and the clock is ticking.
    James
    James Martin replied 18 years, 10 months ago 2 Members · 2 Replies
  • Jerry Hofmann
    November 16, 2007 at 1:49 pm
    Try exporting a self contained movie using current settings. Use that file as source instead of your sequence.
    Jerry
  • James Martin
    November 29, 2007 at 3:42 pm
    Turned out it was Flip4Mac after all – why I orta…!
