Activity Forums Apple Final Cut Pro Legacy Audio Sample Rate but no solution!
  • Audio Sample Rate but no solution!
    Posted by David Peralta on February 28, 2009 at 6:31 am
    Hi all,
    I have an issue that has been addressed in previous posts, but no answer has been able to fix the issue.
    I am capturing PAL footage onto an 2 ghz intel core 2 duo imac, and for five out of 30+ tapes I get the message that the audio sample rate of the captured file does not match the source. They come out significantly out of sync, (not just an offset either, if I sync the beginning the end is out of sync and vice versa).
    The five tapes were from three different cameras (all set to 48khz).
    I have tried capturing from multiple decks to no avail. I have tried exporting the audio at 48khz (even though clip settings lists the clips as 48khz) but still no luck. Capturing shorter clips from the tapes works but is not an ideal solution.
    Any suggestions?
    Dave
    David Peralta replied 17 years, 6 months ago 2 Members · 2 Replies
  • David Roth weiss
    February 28, 2009 at 6:49 am
    It certainly sounds as if the bad tapes were shot at 32khz. Try it out at the very least by copying the 48khz easy setup, then change the audio to 32khz and try capturing a few minutes. If that is the ticket you will know immediately.
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, and Indie Film & Documentary forums.
  • David Peralta
    March 2, 2009 at 3:44 pm
    Thanks so much David.
    That was exactly it. The strange thing is is that all of our other tapes that came from that camera were all shot and captured at 48khz, and no one ever changed the settings. How could that happen?
