Activity Forums Apple Final Cut Pro Audio Roles Issue
  • Audio Roles Issue
    Posted by Daniel Elder on April 14, 2017 at 2:41 am
    So, I posted this earlier this week: https://forums.creativecow.net/thread/344/47055 about my issue with audio roles.
    I didn’t plan ahead and have an edit with over 200 edits for a multicam half-hour sitcom. It is going to take me forever to replace each multicam clip with the proper audio roles with proper names. is there any workaround to sort this issue out? I’m dreading having to go into each clip to fix the roles and the audio for each clip before sending to my audio mixer.
    Please and thank you in advance.
    Dan
    Daniel Elder
    producer
    http://www.elderproductions.com
    Daniel Elder replied 9 years, 5 months ago 1 Member · 1 Reply
  • Daniel Elder
    April 14, 2017 at 3:54 am
    Never mind, I fixed my problem! So, what I figured out is if I go into my timeline and double click and change my audio roles and audio configurations within the timeline / multicam clips, it will ripple through the timeline, thus making the changes a lot easier to make that way! ☺
    So if you ever come across the problem of not properly setting up your Audio Roles and Configurations, just make your changes within your master project timeline and it’ll ripple through.
    Daniel Elder
    producer
