Activity › Forums › Apple Final Cut Pro Legacy › Audio Render time with DV Stream file (.dv)
Rafael Amador replied 16 years ago 3 Members · 15 Replies
John Pale
September 20, 2010 at 8:11 pmThe default setting is upper field in MPEG Streamclip…it’s made by an Italian company, where they use the PAL system, which is (mostly) upper field.
NTSC (SD) is lower field first. If you are working in NTSC you should change it . -
Rafael Amador
September 21, 2010 at 1:42 am[John Pale] “NTSC (SD) is lower field first. If you are working in NTSC you should change it .
Not always John.
I’ve found NTSC DVDs with Upper First on the MPEG-2.
This is why I told Jenny to check the Stream Info,
rafael -
John Pale
September 21, 2010 at 1:56 am[Rafael Amador] “Not always John.
rafael
“Thanks. I’ve never encountered one, but you are right. Its good to check.
Jenny Mettee
September 21, 2010 at 2:16 amThanks for everyone’s help, for some reason the DVD’s sent to us are upper field first.
Should the file size be a lot more for ProRes than DV? We are working with limited HD space.
Rafael Amador
September 21, 2010 at 2:28 am[Jenny Mettee] “Should the file size be a lot more for ProRes than DV? We are working with limited HD space.”
Will be a bigger files, but this is the only way if you don’t want to compromise the quality.[Jenny Mettee] “for some reason the DVD’s sent to us are upper field first.”
Keep an eye on this for the rest of the job.
FC and Compressor expect an Lower-first clip.
rafael
