Activity › Forums › Adobe After Effects › audio render out of sync?
  • audio render out of sync?
    Posted by Knubile on June 12, 2006 at 9:34 pm
    I am having a problem with rendering. I’m also new to this.
    I’ve narrowed down my issue to this very simple test. I have an mpg with video and audio. I import it into after effects and tell it to render an mpeg, avi or quicktime file.
    When I render it the audio is about 1 second behind the video. I’ve tried this with numerous encoders. They all give the same result. What could be causing this?
    I know its not the source video. It plays perfect in a variety of players.
    Any thoughts?
    Ebarfield replied 20 years, 3 months ago 2 Members · 1 Reply
  • Ebarfield
    June 12, 2006 at 10:45 pm
    If you have Premiere Pro, you can try importing the mpeg file, then exporting to a movie (.avi) and test with windows media player, or other players. Then bring this .avi into After effects, if you want to go further. I seem to recall that earlier versions of After Effects did not like mpeg, but not sure.
    Or, you could use a number of other converters. I always use Premiere Pro or Ulead Video Studio (an older version…I think 7.x) to do my conversion of mpeg to avi. NOt sure about quicktime .mov.
    later,
    egb
    “deja vu all over again” — Yogi Berra
