Activity Forums Apple Final Cut Pro Legacy Audio Render Issue — reached render limit?
  • Audio Render Issue — reached render limit?
    Posted by Ben Caro on April 3, 2014 at 11:11 pm
    Hi there,
    I tried searching for this issue and couldn’t find a solution. I was handed a pretty large 38 MB documentary project to work on with a couple of sequences. The first cut of the film was split into a Part 1 sequence and a Part 2 sequence. Part 1 worked fine. With the same sequence settings, and even the same media, the audio in Part 2 needs to be rendered if moved. This only occurs with the main footage, which displays a rainbow of colors on the clip itself: orange, white, red, blue.
    After experimenting, I’ve found that though the audio can be moved in Part 1 without a re render, if I add new content to the sequence, the render issue behaves the same. It makes me wonder whether I’ve hit some sort of “limit” on rendering audio. After trying a new project, or changing my scratch disk, though, the same thing occurs.
    Here are the specs on the footage:
    ProRes 422
    29.97
    48 KHz
    32-bit Floating
    I would appreciate anything that would allow me to edit on the second timeline without having to re render!
    Nick Meyers replied 12 years, 5 months ago 2 Members · 3 Replies
  • Nick Meyers
    April 4, 2014 at 1:41 pm
    up the number of real time audio tracks you can play in FCP in your user prefs
    default is 8… measly!
    nick
  • Ben Caro
    April 4, 2014 at 5:50 pm
    The Part 2 audio footage is the same as the Part 1, really. (I should really refer to these things as Sequence 2 and Sequence 1). Both sequences are set to:
    2 Outputs
    48KHz
    Depth: 24 bit
    32 Bit Floating Point
    And unfortunately it’s not a problem of RT audio tracks. It’s just the A Roll — I’m only using the first four tracks. :/
  • Nick Meyers
    April 5, 2014 at 3:18 am
    are there any filters on the audio?
    pitch correction, for instance uses up a lot of track allocation.
    oh, and the real question is what is the format of the FOOTAGE?
    nick
