Activity Forums Apple Final Cut Pro Legacy Audio Render Includes Incorrect Region
  • Audio Render Includes Incorrect Region
    Posted by William J. meyer on May 14, 2008 at 8:33 pm
    Hello,
    Occasionally when I do an audio render for playback (using 6-12 tracks) the resulting audio on the timeline includes an incorrect range from the correct audio file. Although I do not know why FCP would choose a different range than the one specified by my In and Out points, this seems to only occur when I mix audio sources of different kHz and bit rates. In the past I have converted the files in the minority to match the settings of the majority (usually the field audio), and although that works…in my current situation I have numerous audio files with various kHz and thought perhaps there was another workflow rather than converting a multitude of audio files. And maybe the render issue is something else entirely? I have the “Real Time Audio Mixing” pref set to 12.
    Thanks for your help!
    Take care,
    wjm
    MacPro 8-core (2X 2.8GHz Quad-Core Intel Xeon 5400)
    ATI Radeon HD 2600 XT
    Now in post-production
    The House That Jack Built
    https://thehousethatjackbuilt.wordpress.com
    William J. meyer replied 18 years, 4 months ago 1 Member · 0 Replies
  • 0 Replies
