Activity Forums Adobe Premiere Pro Audio Render files in sequence composed of Multicam Clips ENORMOUS. Cannot export!
  • Audio Render files in sequence composed of Multicam Clips ENORMOUS. Cannot export!
    Posted by Basia Winograd on July 21, 2014 at 2:09 am
    Hello,
    I just switched from FCP a few months ago. I am editing on a brand new 2.8 Ghz i7 Mac with 8GB Ram.
    My project is 53 minutes long and made up of clips from about a dozen multicam sequences.
    The client wants to see a rough cut on DVD. I figured this should be a fairly simple operation, but when I Export –> Media and select the setting for DVD, it tells me it will take over 3 hours to render audio. So, I set it to do the task over night, but that didn’t help because the render files were so huge — 20 -30 gigs each, that they filled up my hard drive before the project finished rendering. I don’t have a spare drive with enough space for these enormous render files, though if that’s the only solution I may have to get one.
    I feel like there must be a simple work around? Sure, there are a lot of audio tracks in this project, but…it’s hardly unusual. I tried exporting an XML to FCP, but it did not work, probably because of the multicam sequences.
    THANK YOU!
    Tero Ahlfors replied 12 years, 2 months ago 2 Members · 1 Reply
  • Tero Ahlfors
    July 21, 2014 at 4:25 am
    What are the EXACT export settings and what exactly are you exporting? A 53 minute timeline really shouldn’t take 30 gigs of space in MPEG2.
