Activity Forums Apple Final Cut Pro Legacy Audio Remap (slow down audio WITH affect on pitch)
  • Audio Remap (slow down audio WITH affect on pitch)
    Posted by Kristian Engelsen on June 3, 2010 at 7:14 pm
    Hey!
    I didn’t get an answer in the basics section. I guess this not possible: Is there anyway to remap audio so that it plays slower, with the pitch for slow audio and everything, inside FCP? Without going outside to Soundtrack Pro? I don’t think it is possible in FCP, but I hope you guys know for sure? Like you see in this video:
    https://www.youtube.com/watch?v=pnhCxqkHXz4
    Its at 4 second! and some other places out in the vid!
    Kristian Engelsen replied 16 years, 3 months ago 2 Members · 6 Replies
  • Null @Devnull
    June 6, 2010 at 4:04 pm
    Maybe one reason you didn’t get a response is because after watching 2 minutes of the sample video I still haven’t heard what you are asking about. Painful. But the process is simple. If the audio is separate from the video simply select it in the timeline, type “command-j” and chose a speed percentage of less that 100. If it’s still linked to the video, type “command-L” to unlink it first. There are also controls for having the audio change speed over time.
    fledgling editor
    professional slouch
  • Kristian Engelsen
    June 6, 2010 at 7:25 pm
    Hey! Thanks for answering. The sample is the first skateboard trick the little black kid does out the small 3 step staircase on the very beginning of the clip. When he lands with crossed legs on his board. They slow down the video and the audio together. I wonder how I can do this in FCP, to put it simple. I apologize for the bad explaining. I hope you understand what I mean know?
  • Kristian Engelsen
    June 6, 2010 at 7:35 pm
    If you want some more samples of it, it can be found at 2:37 to 3:12 and at 3:38min in the clip
  • Kristian Engelsen
    June 6, 2010 at 8:23 pm
    Thanks for the info on cmd+j and all, but I’m talking about remap it with the pen tool, just like you do with the speed of the video. Is that even possible? I know it is possible with the audio effects, but can you change audio speed as well?
  • Null @Devnull
    June 6, 2010 at 8:53 pm
    Using the Time Remap tool (or graph) kills the sync between audio and video. I think you might try using something like AfterEffects, or just change the speed between 2 points in FCP. It won’t be a smooth ramp up and down, but that might be less of an issue than you would think.
    fledgling editor
    professional slouch
  • Kristian Engelsen
    June 7, 2010 at 7:14 am
    I guess I have to do it in After Effects. But it would be nice to be able to do it directly in FCP. Thanks for answering!
