Activity › Forums › Adobe Premiere Pro › Audio Recover
  • Audio Recover
    Posted by Jairo Gómez on September 26, 2008 at 3:06 am
    I have always wonder if there’s a way to recover the audio track from a clip that has been edited into a project with a diferent audio track without actually having to find the original clip extract the audio and replace it into the timeline…it has to be an easier way.
    Sorry if my english it’s bad, but is not my native language.
    Jairo Gómez replied 17 years, 11 months ago 2 Members · 2 Replies
  • Troy Murison
    September 26, 2008 at 5:44 pm
    Sure- use the match frame function-
    Here’s what I would do:
    In the timeline, highlight (select) the clip you want audio for and park the playhead at it’s first frame. Set your target track to the video layer that clip resides on, un-target any audio layer that might be targeted, press the ‘/’ (forward slash) key to mark the in-out of the clip, then press the ‘m’ key and the source clip will be loaded into the source window with the playhead parked at the same source frame your playhead is at in the timeline. Mark a in point for the clip in your source window. Target the audio track you want to edit into, deselect your video track (or not if you don’t have any effects or transformations applied) and perform a overwrite edit. Done. The only thing that sucks about this in PPro is that to select in-out for any clip on the timeline, you first have to highlight or select it. Dumb. But this should get your audio back in sync on the timeline relatively quickly.
    Hope that’s what you meant and that this helps a bit.
    -Troy Murison
    Seattle, WA
  • Jairo Gómez
    September 28, 2008 at 5:19 pm
    Thanks Troy
    it was helpful
    bye
