Activity Forums VEGAS Pro Audio recording problem
  • Audio recording problem
    Posted by Doyal Gudgel on June 9, 2011 at 6:03 pm
    Audio track does not indicate I am recording although the record button is depressed below the track and the Vue meter indicates the amplifier is working. I inserted the audio track. . I got it to work once but don’t know what I did right.
    Doyal Gudgel replied 15 years, 3 months ago 3 Members · 3 Replies
  • Danny Hays
    June 12, 2011 at 4:36 pm
    You may have audio device driver issues. I would try downloading the newest drivers for your sound card or device. Also make sure you select the right input before recording. The track should turn pink as the curser moves when your record audio. Hope this helps, Danny Hays
  • Doyal Gudgel
    June 12, 2011 at 6:10 pm
    I had recorded just a few days ago so the drivers should be up to date. Maybe I changed something. I will check
    Hope to see you
    https://seniorobserver.blogspot.com, https://billswar2.blogspot.com
  • Doyal Gudgel
    June 13, 2011 at 12:50 am
    I found it out of sight. OK Now
