Activity Forums Adobe After Effects Audio react plugin or script?
  • Audio react plugin or script?
    Posted by Yanda Satria on September 5, 2017 at 9:24 pm
    So, i know how to do audio react, by using audio waveform or spectrum, or do it manually using keyframe assistant and so on…
    mostly i use the keyframe assistant technique, but, now i’m working with a band which constantly produce song with audio react motion graphic background…and…
    i am wondering if there are any plugin or script that does audio react, like trapcode form’s audio react…which will save me some time…
    form’s audio react is already good enough but it requires me to put 1920×1080 particle which is so heavy to render.. ☹
    i’ve search the internet but no luck so far, the closest one is something called 3d audio react but it’s in korean… ☹
    thanks
    Yanda Satria replied 8 years, 11 months ago 2 Members · 2 Replies
