Activity › Forums › Apple Final Cut Pro Legacy › audio questions
audio questions
Posted by Sergio Deustua on January 31, 2006 at 12:01 pmi have two questions:
1) How can I erease a group of key frames when I
Jason Brown replied 16 years, 5 months ago 4 Members · 3 Replies -
Samuel Frazier
January 31, 2006 at 6:21 pmNo expert but I’ll try
1- Not sure what you mean by group of keyframes. Do you mean keyframed volume changes in individual clips? The only way I know is to delete each clip’s keyframes one by one. I believe the toggle on the bottom of the screen only turn visability on and off, but the keyframes are still applied. So I’m not sure if there is a faster way to do this, but I hope I’m wrong.
2- This just doesn’t sound right at all. It’s happened to be and I had to restart the computer, then all was fine. Might try that, then the old trashing preferences and possibly render files if all else fails.
Sorry, wish I could be better help!
Frank Nolan
January 31, 2006 at 7:19 pm[langosta] “1) How can I erease a group of key frames when I
Jason Brown
April 12, 2010 at 3:22 amI know this is an old post, but in case you are interested, I just found this out today:
https://www.jbtwist.com/CC/delete_audio_keyframes.mp4
