Activity Forums VEGAS Pro Audio question when rendering
  • Audio question when rendering
    Posted by Frenchie29 on December 4, 2007 at 7:54 pm
    I posted another post earlier regarding capturing, now that the problem is fixed I have another question.
    When I shot the footage I used mic input 1, the feed is from an audio mixer, as a a mono signal. I would like to know what is the best option for rendering the video? should I ive it as it is, stereo with only one channel (left) of audio? or sum the 2 tracks as a mono feed. I think that would be the best thing, but since there is no signal on the right chnnel I don’t know if that’s proper.
    MPAUDIOVISUAL.com
    Edward Troxel replied 18 years, 9 months ago 4 Members · 16 Replies
  • 16 Replies
  • Edward Troxel
    December 4, 2007 at 8:26 pm
    I would right-click it, choose Channels, and pick LEFT ONLY. This will output the left channel on both sides. If you “sum” it and there’s any garbage on the right channel, it would be put into the mix as well. I think “Left Only” would be the better option.
    Edward Troxel
    JETDV Scripts
  • Frenchie29
    December 4, 2007 at 11:03 pm
    Perfect , thank you.
    I just realaized that I should of recorded the cam shotgun mic on ch 2. Could of been costly.
    MPAUDIOVISUAL.com
  • Frenchie29
    December 5, 2007 at 12:04 am
    Strange, for some reason thre’s no sound when I am playing it from my dvd player, but I get sound while playing with my PC
    MPAUDIOVISUAL.com
  • Rick Mac
    December 5, 2007 at 1:04 am
    [Martin Premont] “for some reason thre’s no sound when I am playing it from my dvd player, but I get sound while playing with my PC”
    Does your DVD have audio when played on your computer?
    If no, you most likely did not render out the audio portion of your project. What program are you authoring your DVD with?
    Regards, Rick.
    Rick Mac
    Director of Audio Production
    TCT Network – Directv 377
  • Frenchie29
    December 5, 2007 at 1:25 am
    Yes there’s audio while playing on my PC
    The thing is the client wants the raw footage, no editing whatsoever, so what they told me to do is just to put the footage on 2 DVD 9 as data DVD format. But usually I still can have audio when I transfer that way.
    MPAUDIOVISUAL.com
  • Rick Mac
    December 5, 2007 at 3:11 am
    [Martin Premont] “so what they told me to do is just to put the footage on 2 DVD 9 as data DVD format.”
    So you are trying to play a data dvd on a stand alone dvd player?
    Rick Mac
  • Frenchie29
    December 5, 2007 at 3:22 am
    Yes, an mpeg2 file I get picture but no audio
    MPAUDIOVISUAL.com
  • Mike Kujbida
    December 5, 2007 at 3:51 am
    Did you make sure that the MPEG-2 template you used was set to include audio?
    Some do and some don’t so you need to make sure you picked one that does.
    You can also go into the Audio tab of the Custom options and make sure that “Include audio stream” is selected.
  • Frenchie29
    December 5, 2007 at 4:18 am
    Yes it’s included, otherwise I couldn’t get any audio with the same DVD in my PC what I am thinking is my DVD player might be too old to read that kind of audio file, would that make any sense??
    The thing is the client wants to use those DVD’s just to arhive the meeting, it’s fine playing from a computer but I’d rather give them something they could use on both.
    MPAUDIOVISUAL.com
  • Mike Kujbida
    December 5, 2007 at 4:30 am
    Yes it’s included, otherwise…
    Martin, I never assume anything so I’m just making sure 🙂
    Now for another potentially dumb question.
    How are you putting the video onto the DVD?
    Are you creating a DVD in DVD Architect (i.e. AUDIO_TS & VIDEO_TS folders) or just dropping the MPEG-2 file onto a disc?
    If it’s the latter, then I suspect that’s why it won’t play properly on a DVD player.
