Activity Forums Live Events & Streaming Audio question about person playing the Harp
  • Audio question about person playing the Harp
    Posted by Linda O’connell on February 26, 2009 at 12:22 am
    I am not really sure which forum this should go in..but..
    I got a call from someone today who wants me to film her playing the harp. She is going to use the dvd to apply to music colleges.
    My question is this: What is the best microphone to do this? Should I use a lapel microphone and put it on her? On the harp itself or use a boom?
    I really haven’t done anything like this before, so any advise would be appreciated.
    Thank you in advance.
    Bill Davis replied 17 years, 6 months ago 2 Members · 1 Reply
  • Bill Davis
    February 28, 2009 at 11:51 pm
    The harp, like the piano is a kinda complicated thing to record.
    I’d stay away from lavs or any kind of contact mics.
    The traditional technique is a stand mounted condensor mic placed at least as far away from the instrument as the instrument is tall.
    The space around the harp is also important. A quiet sound field and a space large enough to let the instrument sounds intermix prior to getting to the mic will get you the best results.
    Do a web search under “micing a harp” and you should find some manufacturers recommendations.
    I think the traditional mics are either large diaphram condensers like the AKG-414 or small diaphram condensors like those from Schoeps or Audio Technica.
    Just bring a way to monitor what you’re recording (decent headphones!) and use the best gear you can get your hands on without going too nuts.
    Really, there are proabably a couple hundred microphones from many manufacturers and models that can do a workmanlike job of recording this. And if you can’t get anything but a Shure SM-57 don’t let that stop you. Just move it around until the lower end and upper end are sorta in balance and toss a heavy blanket over the refrigerator or anything else making noise in the background and do the best you can.
    Good luck.
