Activity Forums Apple Final Cut Pro audio question about 2 chanels on one track (!?)
  • audio question about 2 chanels on one track (!?)
    Posted by Julian Bowman on January 31, 2013 at 3:48 pm
    Hi, I use DSLRs and record to a audio harddrive. When I have two subjects I record one to each side of a stereo wav. In FCP7 I would simply drop the audio into the timeline, unjoin them and move the pan from -1 and +1 to 0 on each and was happy.
    So in X I have used the sync option to join my audio to my video. I have managed to change the audio to Dual Mono and the pan is down the middle for both, which is great, but I don’t see how to change the volume level for each one separately in case I want it more balanced. There are the waveforms mono1 and mono2 in the Connected area of the Channel Config of the Audio Inspector, but I cannot do anything on that other than turn either off. And when I detach audio in the timeline it just gives me one audio track of the combined dual mono tracks.
    JUST SOLVED IT:
    Once you detach audio you then right click and expand audio components, that gives me both the mono files. Cool, glad it is there. All a bit convoluted though isn’t it?
    Am leaving this post anyway in case it has some value to someone else trying to figure this out.
    Cheers
    Julian Bowman replied 13 years, 7 months ago 3 Members · 4 Replies
  • Jari Innanen
    January 31, 2013 at 5:22 pm
    No need to detach first. Opt-Click will expand audio components.
  • Julian Bowman
    January 31, 2013 at 7:12 pm
    Cheers Jari.
    In fact since posting I have discovered that detaching isn’t very wise at all as you can’t reattach without creating a compound clip, so yes expand, do your business, then close 🙂
  • Jeremy Garchow
    January 31, 2013 at 7:47 pm
    You can select all the relevant clips in the Event Browser, go to the audio portion of the inspector, and change the setting to dual mono.
    This will ensure that every time you add a clip, it will be dual mono.
    You can then adjust the levels separately in the timeline as has been already mentioned.
    Jeremy
  • Julian Bowman
    February 1, 2013 at 7:05 am
    Cheers Jeremy, nice to know it can be done as a group. Appreciated.
