Activity Forums Adobe Premiere Pro Audio question
  • Audio question
    Posted by Shane Worth on May 22, 2012 at 4:38 pm
    Hey there, I mostly use final cut pro x but decided I want to start doing more with premiere. My question is that I have a .mov file movie I made in final cut pro. I am re-editing in premier to tweak it because my desktop is apple and my laptop is pc I have premier on the pc so I have my .mov on my external harddrive. Anyways I am able to edit it ok but the audio from my .mov clip has no wave forms and it won’t let me do any audio effects what so ever. if I drop in and mp3 or what ever that works fine just wondering if my mov audio although it plays is wacky and I need to convert the audio or something. I am in no way an audio guy Thanks for your help.
    here is my clip properties:
    Type: QuickTime Movie
    File Size: 51.7 GB
    Image Size: 1920 x 1080
    Pixel Depth: 24
    Frame Rate: 29.97
    Source Audio Format: 48000 Hz – 24 bit – 6 channels
    Project Audio Format: 48000 Hz – 32 bit floating point – 6 channels
    Total Duration: 00;51;52;02
    Average Data Rate: 17.0 MB / second
    Pixel Aspect Ratio: 1.0
    QuickTime Details:
    Movie contains 1 video track(s), 1 audio track(s) and 1 timecode track(s).
    Video:
    There are 93270 frames with a duration of 1/29.97th.
    Video track 1:
    Duration is 0;51;55;05
    Average frame rate is 29.98 fps
    Video track 1 contains 1 type(s) of video data:
    Video data block #1:
    Frame Size = 1920 x 1080
    Compressor = Apple ProRes 422
    Quality = Most (5.00)
    Audio:
    Audio track 1 contains 1 type(s) of audio data:
    Audio data block #1:
    Format = 24 bit – Stereo
    Rate = 48000 Hz
    Compressor = lpcm
    Timecode:
    Timecode track 1 contains 1 type(s) of data:
    Timecode data block #1:
    Start Time = 00;00;00;00
    Reel name =
    Shane Worth replied 14 years, 4 months ago 1 Member · 0 Replies
  • 0 Replies
