audio question
Posted by Larry Watts on July 26, 2006 at 3:11 pmIs there a way to recombine audio that has been split up with the video so I can normalize it as a unit.?
Stephen Mann replied 20 years, 2 months ago 3 Members · 4 Replies -
Gary Kleiner
July 26, 2006 at 3:58 pmNormalize will apply to all selected audio events.
Gary Kleiner
Learn Vegas and DVD Architect
http://www.VegasTrainingAndTools.com
Larry Watts
July 26, 2006 at 5:02 pmGary,
Yes, but doesn’t it normalize based upon the section? If you have an audio track that is split between sections won’t it have a different normailzation?Larry
Gary Kleiner
July 26, 2006 at 7:56 pm[TalbotGrad] “If you have an audio track that is split between sections won’t it have a different normailzation?”
Yes, if the peaks are different.
Gary Kleiner
Stephen Mann
July 27, 2006 at 7:49 amSo, you hit the “S” key and both audio and video split? Just making sure I know how you got here… If you didn’t change the timeline with cuts or inserts and the audio track is good except for the splits, then you can delete all but the first event then just drag the right edge to the end. (When you get a loop mark, then you’ve gone past the end.)
If you’ve done edits that change the audio timeline, then you could render the audio to a new track and normalize that.
Stephen Mann,
MannMade Digital Video,
San Jose, CA
