Activity › Forums › Apple Final Cut Pro Legacy › Audio Question
Audio Question
Posted by Luke Pearson on June 18, 2007 at 4:50 pmI’m capturing video into my system. The video was recorded with 12 bit audio. Should I change all my settings for final cut to match this 12 bit audio?
Jerry Hofmann replied 19 years, 3 months ago 2 Members · 3 Replies -
Jerry Hofmann
June 18, 2007 at 5:28 pmYeah… set your audio capture presets to be 32 kHz, 16 bit.
You can do this with a custom capture preset… duplicate the one you’re using now, then change it’s audio capture preset to the above…
Jerry
Apple Certified Trainer
Author: “Jerry Hofmann on Final Cut Pro 4” Click here
Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
Luke Pearson
June 18, 2007 at 5:38 pm“Yea”, set them to match the 12 bit? or change them to 16 bit? I’m sorry. Audio confusses me sometimes.
Jerry Hofmann
June 19, 2007 at 10:16 pmYes… change the capture preset to 32kHz, 16 bit. That will match the sample rate of a 12 bit audio recording. If you don’t do this and capture at 48 kHz, 16 bit, you’ll have the problems you’re seeing now.
Jerry
