Activity Forums Avid Media Composer Audio Punch-In Problem
  • Audio Punch-In Problem
    Posted by Nick Desantis on February 14, 2008 at 8:18 pm
    Hi everyone-
    I’m trying to use Avid’s audio punch-in tool to record some VOs for a few news packages that I’m cutting. Currently, I’m using Xpress Pro 5.7 Academic for Windows, and I’m running a Behringer mixer through one of their FCA-202 FireWire interfaces and into my machine.
    When I bring up the audio punch-in tool and try to use it, 2 things happen. If I attempt to select “Host 1394” in the “Input Source” window – which, I assume, should recognize my FireWire equipment – and hit play or record, I get a message saying “The Punch-In device is not ready.”
    When my audio equipment is hooked up, I get a second option for the “Input Source” – called “Windows Mixer.” If I try to use that to record my audio, it appears as if it might work, and then I get the following error message from Avid:
    SampleTransferSpeedStrategy: TransferRecordSamples()
    Error [223322] unable to:
    Lock capture buffer for take.
    It seems like Avid should recognize my FireWire equipment, but it doesn’t. If I try something different, it gives me the above message. Any ideas?
    Candida manzueta Reyes replied 16 years, 5 months ago 3 Members · 2 Replies
  • Grinner Hester
    February 14, 2008 at 8:27 pm
    you are best off just turning off deck control and crash recording the vo.
  • Candida manzueta Reyes
    April 14, 2010 at 8:53 am
    How do I turn off the deck control and and crash recording the vo? I deeply need help. And, when you are gonna explain this to me, pretend that is a child you are talking too.
    Thank you..
