Activity Forums Apple Final Cut Pro Legacy Audio pulldown for 23.98
  • Audio pulldown for 23.98
    Posted by William Watts on August 1, 2006 at 9:25 am
    FCP 5.0.4,working in 23.98 from rushes on HD Cam SR.Audio mixer op is being rec to the HDCam,capture is coming SD out of SRW1 via Decklink Pro (embedded 48k audio).All FCP settings are for 23.98,the audio is slipping synch to picture.Is there an audio ‘pulldown’ setting for the audio somewhere,or should I be going the other way round and using a 24fps editing base ?
    Will.
    (Soho Asia Co. Ltd.,Bangkok)
    William Watts replied 20 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
