Activity › Forums › VEGAS Pro › Audio problems when Rendered and played back on a TV
  • Audio problems when Rendered and played back on a TV
    Posted by James Saunders on December 12, 2008 at 12:17 am
    It seems that I have better luck in here than the Basics forum (Sorry for the double-post):
    Basically what the title says. It all sounds great on my computer, but after I’ve rendered everything and put it together on a DVD- certain TV’s get sound issues. Either it’s too low or a song won’t be playing at all or a voice over won’t be playing at all.
    Is there anyway to change the settings before rendering so that it’s an accurate display of what the sound should be?
    Mike Kujbida replied 17 years, 9 months ago 3 Members · 4 Replies
  • Mike Kujbida
    December 12, 2008 at 1:00 am
    Assuming you’ve gone through your audio before encoding and the levels are all OK, here’s an AC-3 adjustment to make.
    Encode set to AC3;
    Click on Custom tab;
    On the first tab, set Diag. Norm to” -31″;
    On the last tab marked Preprocessing, set the Line Mode Profile
    and RF Mode Profile mode to “none”;
    Save this as a preset.
  • Stephen Mann
    December 13, 2008 at 1:19 am
    Do I understand that it works on some TVs and not on others? Sounds like (oops, pardon the pun) a channels problem. Did you encode the AC3 file from Vegas and did you encode 5.1, stereo or mono?
    Steve Mann
    MannMade Digital Video
    http://www.mmdv.com
  • James Saunders
    December 19, 2008 at 10:49 am
    Sorry I haven’t checked this sooner, I fixed some of the audio by raising it but are you guys saying that I am supposed to render the audio and video files separately so that it doesn’t mess up on a DVD?
  • Mike Kujbida
    December 19, 2008 at 2:43 pm
    The usual recommendation is that you render your video file (MPEG-2) and audio file (AC-3) separately.
    As long as you give both files the same surname (myvideo.mpg & myvideo.ac3) and render them to the same folder, DVDA will automatically load the audio once it loads the video.
    Depending on the length of the video, you may need to use a bitrate calculator to determine the proper settings.
