Activity › Forums › Adobe Premiere Pro › Audio problems when importing XML file into FCP 7 (Premiere – FCP incompatibility?)
  • Audio problems when importing XML file into FCP 7 (Premiere – FCP incompatibility?)
    Posted by Eren Gulfidan on August 17, 2015 at 8:31 pm
    Hi there,
    When I open the XML file I exported from Adobe Premiere into FCP 7, everything transfers fine except the audio that is linked to the video. I have two audio channels, one exterior recorded with a zoom mic, and the other – a lav, which is connected to the camera. The zoom audio sounds fine except that it is out of sync. But the lav is not even audible. All I get is this loud hissing sound like a broken TV or a radio static. It’s so bizarre! I should also note that some of the clips I have are multicam clips. But even regular one track interview videos have that corrupt audio. I’ve been searching the internet for days to resolve this issue, but haven’t found a solution yet. Please let me know if you think you can help. Thanks so much!
    Eren Gulfidan replied 11 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
