Activity › Forums › Adobe Premiere Pro › Audio Problems
  • Audio Problems
    Posted by Sean Mackin on December 9, 2008 at 1:17 am
    Audio Problems 🙁
    Ok everyone go easy on me I am new to this forum and new to PP. I have been working with the Canon HV20 that I purchased and trying to edit in PP. I have had some success and also a bit of fun creating some different effects etc. I have been able to render my video along with audio files using premiere pro CS3. I have been able to watch and listen to the rendered project with audio using Window Media player after the project has rendered. When I go to export using the Adobe Encoder Blu-Ray after about 10 hours of processing the audio portion is missing, or at least I can not hear it anymore.
    One thing I did notice (after 10 hours had completed) and I am going to change, is the fact that I captured (under general settings) using 29.97 fps but the settings in Adobe encoder were set at 23.976 fps. Would the difference in fps. be enough to completly wipe out the audio?
    One other thing I did was transfered a number of files into an external hard drive to have enough space to render for 10 hours. I was pretty careful to make sure all the project folders remained in the same drive/folder so I couldn’t screw anything up.
    Like I said the video played perfectly in Premiere until I went to decode.
    The general audio settings are at 48,000 Hz and are the same in Adobe encoder.
    Thanks for any help you can offer.
    Thanks for the Help
    Sean Mackin replied 17 years, 9 months ago 1 Member · 0 Replies
  • 0 Replies
