Activity Forums Avid Media Composer Audio problems
  • Audio problems
    Posted by Anthony Rhodes on August 5, 2009 at 3:12 pm
    I have recorded a small video clip but the audio is a bit distorted.
    What I need are specific instructions as to how do I export the audio tracks so that i may run them and correct the audio in another program then re-add them to the Avid system.
    Ryan Mcafee replied 17 years ago 2 Members · 1 Reply
  • Ryan Mcafee
    August 5, 2009 at 3:51 pm
    1. Mark in and out points on the portion of the sequence you are working on.
    2. Click on Sequence you are working on.
    3. Go to File
    4. Go to Export
    5. Go to options
    6. Click on drop down (export As) choose audio
    7. Choose wave(if using adobe) or aiff
    8. Enable use marks (if used)
    9. Click Save
    10. Make File name
    11. Save to directory.
    Open in other editing system then import final piece back into avid as wav file.
    Ryan McAfee
    Moon Community Access Television
    http://www.MCA-TV.com
