Activity › Forums › Adobe After Effects › Audio problems
Audio problems
Posted by Matt Nikkila on January 30, 2008 at 6:24 amI can’t seem to get audio to work in my composition on after effects. I’m tryin to match a heartbeat . mp3 file to text but for some reason i get no audio playback?
What am i doing wrong can anyone help me please?
Matt Nikkila replied 18 years, 8 months ago 3 Members · 3 Replies -
Steve Roberts
January 30, 2008 at 12:26 pmFirst, use Quicktime to convert the file to AIFF or WAV. Then import that into AE. Otherwise, we won’t fix the problem.
Try audio-only playback for the comp containing the audio layer using the . key on the Num keypad.
Try playing a RAM preview for the comp containing the audio layer. This is how to preview in AE — not with the spacebar.
Make sure the little audio button is on for RAM preview.
Make sure the little speaker icon for the audio layer in the comp.If you still can’t get what you want, let us know the conditions (any) under which you can hear the audio.
Aharon Rabinowitz
January 30, 2008 at 3:43 pmregardless of any other issue – MP3’s do not work with AE – no matter what.
They seem to work, until you render.
So as Steve said – always convert your MP3’s into WAV’s or AIFF’s.
Aharon Rabinowitz
Email: arabinowitz (AT) yahoo (DOT) com
All Bets Are Off Productions, Inc.
Creative Cow After Effect Podcast
Internet Killed the Video Star: A Guide to Creating Video for the Web -
Matt Nikkila
January 30, 2008 at 4:37 pmYou guys are the coolest thanks for your help i figured it out. It was imported and converted to a Aiff, i just wasn’t choosing the right option for playback.
As soon as i used the . on the num pad it worked perfectly! Thanks a million!
