Activity Forums Apple Final Cut Pro Legacy audio problems
  • Posted by Joe Huggins on September 20, 2006 at 7:25 pm
    Gentelmen,
    We have FCP 5.0.4 and after a film transfer in DV format, have synced the audio, 2 channels to that. I then exported that as a QT movie. However, my client can see the video fine, but can not hear any audio. I did lay down some audio only clips as raw QT files, and he hears that audio fine. But not the audio I synced to the video, then saved as a DV-size QT combined file. (now the export of audio was noted as 4 channel, but only 2 are used.)
    My client is running v. 4.5. He sees it but can not hear the QT audio. Any clue as to what I’m doing wrong?
    Speechless in Atlanta,
    Joe
    Joe Huggins replied 20 years ago 2 Members · 2 Replies
  • Michael Gissing
    September 21, 2006 at 3:40 am
    Are you both using version 7 QT? The main change from QT6 to Qt7 was the audio. If your client has FCP4.5, chances are he is on QT6.
  • Joe Huggins
    September 21, 2006 at 2:01 pm
    Thanks Michael, we will check those versions.
    Joe
