Activity › Forums › Panasonic Cameras › Audio problem with component out to Marshall monitor
  • Audio problem with component out to Marshall monitor
    Posted by Mark Mcginley on April 27, 2008 at 8:11 pm
    I’ve noticed that I get an audio buzz when I have a mic in the XLR input and a monitor plugged in to the component output. When I plug in a mic in the XLR (1 or 2)input and set it to ‘line’ or ‘mic’, I get this buzz thru my headphones. It’s less pronounced in ‘mic’ mode, but It is still there. As soon as I unplug the component cable from the HVX the noise goes away. I’ve tried running my Marshall monitor on batteries and with a power supply, but it didn’t work. My only thought its that it could be a bad component cable. Any thoughts would be appreciated before I pop for a $50 cable.
    Best Regards
    Mark
    http://www.endlessskyhd.com
    Mark Mcginley replied 18 years, 3 months ago 3 Members · 4 Replies
  • Dave Neyman
    April 28, 2008 at 1:31 am
    I often run a similar setup without experiencing any noise. I don’t think it is a characteristic of the camera so it could be a bad cable. Best of luck.
  • Mark Mcginley
    April 28, 2008 at 2:33 pm
    Thanks Dave.
  • Stuart Duncan
    June 4, 2008 at 11:41 pm
    there is an issue with the 16 and 32GB cards on the p2…….this issue causes a buzzing on recording…
    if you are using a 16 or 32GB card contact your nearest panalogic dealer for service…
  • Mark Mcginley
    June 6, 2008 at 5:56 pm
    Hello Stuart,
    I have two 16GB cards. Did you have the problem? Did you get it repaired? Any additional references to this problem?
    Thanks in advance.
    Mark
