Activity Forums Blackmagic Design Audio problem capture, please help.
  • Audio problem capture, please help.
    Posted by Alejandro Castan on August 17, 2005 at 6:35 pm
    Hello all:
    I have a little problem since I would need to capture with my Decklink extreme card one mini dv ntsc with 32 k audio source from Component Video output and XLR audio output but when I want to capture this the audio I couldn’t do it. I tried with other mini dv ntsc 48 k audio source and I could capture this audio, for that reason, Could anybody advice me about 32 k audio capture with Decklink extreme?
    Thanks in advance.
    Alejandro
    Ps: Sorry for my little english.
    Luke Maslen replied 21 years, 1 month ago 2 Members · 2 Replies
  • Alejandro Castan
    August 17, 2005 at 6:59 pm
    Hello Again:
    Please, don’t worry about my audio problem because I fixed it(I am a little stupid because I forgot set the audio output to 32 k from my mini dv player)
    Thanks anyway.
    Alejandro
  • Luke Maslen
    August 18, 2005 at 7:52 am
    Hi Alejandro,
    Thank you for letting us know that you have solved your problem. That is good news and I appreciate you posting both the problem and the solution as that will help other DeckLink users.
    DeckLink cards use the television standard sample rate of 48 kHz and 24 bit for audio. As long as your audio conforms to this standard, the DeckLink card will accept it.
    Regards,
    Luke Maslen
    Blackmagic Design
