Activity Forums Avid Media Composer Audio problem after installing Media Composer
  • Audio problem after installing Media Composer
    Posted by Kenneth Tolaas on January 14, 2009 at 8:37 am
    Hello…
    I have just upgraded from Xpress pro to Media Composer on one of our machines.
    I have audio on all the files that was already in the projects, but when I import new files, there is no audio on the Audio tool or in the speakers, although the bin says I have V1 A1-2. I can also see that it imports audio before it imports the video. I am quite shure I don’t have wrong sample rate.
    Are there any new things that I need to check on import i Media Composer..? Any of the projects settings that can sause trouble..?
    Thanks for any help,
    -Kenneth =)
    Kenneth Tolaas replied 17 years, 8 months ago 3 Members · 4 Replies
  • Bill Ravens
    January 14, 2009 at 12:44 pm
    This is a very complicated issue. I would try to uninstall MC, then re-install. Audio compatibility with MC is problemmatic. Do you have ProTools installed on the same OS?
  • Kenneth Tolaas
    January 14, 2009 at 12:52 pm
    I have not had ProTools earlier, at least, I don’t know if it’s a part of the Media Composer-package now..?
    Otherwise uninstall/install would be the best suggestion..?
    hmpf…
  • Scott Cumbo
    January 14, 2009 at 1:16 pm
    are you clips 48k? make sure your clip and project sample rates match. MC defaults to 48k.
    Scott Cumbo
    Editor
    Broadway Video, NYC
  • Kenneth Tolaas
    January 14, 2009 at 1:28 pm
    Yes, all is 48k…
