Activity Forums Adobe Premiere Pro Audio problem..
  • Audio problem..
    Posted by Peilin on April 6, 2006 at 7:50 am
    hi, i’ve encounter a problem with Premier Pro trial version which i just installed. When i export my movie in stereo settings, there’s no sound in the right speacker. While it works fine when i’m running it in the timeline and export it in mono settings. Besides, the funny thing is that i can’t find my panning control in my audio mixer. Is it some settings problem or incompletion of trial version? Please help..
    Thanks!!
    Mike Velte replied 20 years, 5 months ago 2 Members · 3 Replies
  • Mike Velte
    April 6, 2006 at 8:14 pm
    Does the waveform in the timeline display in both stereo channels or did you use an external mic and recorded only one channel?
    Use the Fill Left or Right effect to copy sound from one channel to the other.
  • Peilin
    April 7, 2006 at 2:07 am
    Thanks for your quick reply, Mike. Yes, there’s waveform in the timeline display in both stereo channels. I did not record the audio, it is a mp3 track I copied from a CD. The Fill Left or Right effect does’t help as well. It plays perfectly well in both channels while in the timeline or when it is exported as mono settings. Only when it is exported in stereo settings, the audio will pan to left and there will be no sound in the right. Is this a rare problem that i encounter?
    Thanks again!
  • Mike Velte
    April 7, 2006 at 11:33 am
    Mp3’s are often not a good source…email me a short segment to test…velte@cox.net
