Activity › Forums › Adobe After Effects › Audio problem
  • Audio problem
    Posted by Ohthisguy on March 22, 2007 at 8:41 am
    Hi everyone,
    I added an audio clip into the timeline but I didn’t hear it when I rendered my project. What can I do so that the audio is heard? Any advice will be greatly appreciated.
    Kevin Camp replied 19 years, 6 months ago 2 Members · 1 Reply
  • Kevin Camp
    March 22, 2007 at 2:10 pm
    when you set your output mudule in the render queue, you will need to turn on audio with the appropriate settings… if you click the output module name (like lossless), the audio setting will be near the bottom of the settings window.
    if you output with audio often you can set up a custom output modle and save it, then you can just select it from the pulldown the next time you need it.
    Kevin Camp
    Designer – KCPQ, KMYQ & KRCW
