Activity Forums Apple Final Cut Pro Legacy Audio Problem.
  • Posted by David Jim on November 25, 2014 at 7:12 pm
    Hi, I really don’t know if this is where I should post this but I’m guessing its the best bet!
    I stupidly recorded some audio in an interview really low on my Tascam DR 60D. I’m not actually sure
    what I did. I was in a rush and didn’t check the levels. I’m not a soundman but that’s no excuse.
    Anyway, when I play it on my Mac it sounds okay volume if everything is turned up to the max. So the loudness is there, without distortion, but when I bring it into FCP 7, I can’t bring the levels up that high. It still sounds really too quiet.
    I was wondering if there’s any program or way of changing the levels to have it saved at that volume so I can get away with it! I know if I played it back and re-recorded it with Audio Hijack it should work, but I’m sure there’s gotta be a better way.
    Please someone help me hide my mistake! 🙂
    Cheers!
    Joe Barta iv replied 11 years, 10 months ago 2 Members · 1 Reply
  • Joe Barta iv
    November 25, 2014 at 8:19 pm
    Try the old non-linear trick of copying and pasting the audio on a track just below the original. In a sense, doubling the audio output. Do this copy/paste as many times as you need to bring it up to level.
    Also a simpler way, you add a gain filter to the clip. Effects/Audio Filters/ Final Cut Pro/Gain
    Living the SuiteLife!
    Stuff for editors http://www.cafepress.com/suitelife
