Activity Forums Adobe After Effects Audio Problem
  • Audio Problem
    Posted by Eyad Abutaha on June 12, 2008 at 12:44 pm
    I have a small Audio problem, which is; when I do the final rendering I noticed a delay of a second or even less; which cause the match with the animation to be off; any suggestions
    Am using the animation lossless to render
    Eyad Abutaha replied 18 years, 3 months ago 2 Members · 2 Replies
  • Kevin Camp
    June 12, 2008 at 2:20 pm
    many audio problems can be traced to compressed audio formats like mp3s. is the source/audio track a compressed format? if so, use an audio utility to convert to a wav or aiff and use that in your composition.
    other potential issues can be with the audio rate… if your file 44100, then make sure your project settings are set for 44100 and your audio render settings are also set to that rate.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Eyad Abutaha
    June 12, 2008 at 11:56 pm
    Yes it is an mp3 format; I will try to convert it to wave, also at toolfarm they suggest that when I RAM preview it has to be set to full quality and full resolution this cause the audio to be off; I will take this into consideration too.
