Activity › Forums › Apple Final Cut Pro Legacy › audio problem
  • Posted by Alkaline on November 4, 2006 at 6:47 am
    ok. so I started on a wedding project for my cousin and hit a problem straight away. I imported an Audio track into the browser then pulled it to the viewer where it plays back fine. So i insert it into the timeline and when I play the track in the timeline it crackels playes slow and sounds horrible. I have converted the audio so it matches my sequence settings. I have never had this problem before.
    It is the first time on a HD project but I can’t see that effecting the audio?….
    can someone please help me as I cant progress untill I figure it out.
    thanks Dane Scotcher, Australia.
    Ben Holmes replied 19 years, 11 months ago 3 Members · 2 Replies
  • Bill Lee
    November 4, 2006 at 7:35 am
    Your timeline (sequence) audio setting don’t match your imported audio settings, so when it attempts to play back your audio in the timeline format, it is not keeping up.
    It’s a classic problem in FCP, especially with mp3s and Audio CD-sourced files.
    I presume this wedding video is going to end on DVD-Video (PAL). If so, go to Final Cut Pro>Easy Settup
  • Ben Holmes
    November 4, 2006 at 9:36 am
    Dave
    I’ve had a couple of similar problems recently, one of which was SD and one HD… In one case it was exactly as you describe, with broken up audio on the timeline – and it’s obviously got nothing to do with sequence settings…
    I fixed that one by starting a new timline in the project, after trashing the prefs. The second time I had to reinstall FCP, although it was on a system with a faulty video card, so…
    I wonder if anyone else has seen this recently?
    Editec Broadcast Editing Ltd
    EVS & FCP specialists for live OB operations. FCP systems just used on Sky Sports coverage of the Ryder Cup – live from the K Club.
    “The Supercar Run” now available for international distribution from http://www.electricsky.com
