Activity › Forums › Apple Final Cut Pro Legacy › audio problem
audio problem
Posted by Sergio Deustua on February 7, 2006 at 4:23 pmthe problem is that audio was recorded with timecode frame rate at 25. Video is on panasonic high definition, so audio must be in 29,97. How can i convert 25 to 29,97?
Sergio Deustua replied 20 years, 7 months ago 3 Members · 4 Replies -
Jerry Hofmann
February 7, 2006 at 5:13 pmDub it would be my first choice. via analog… tell them to do it right next time.
Jerry
Sergio Deustua
February 7, 2006 at 5:22 pmThnks jerry.
How an I dub it when audio are digital wave files. They where recorded in a digital audio recorder.
No matter how many times I tell them to do it right, it don -
Creative Animal jan
February 7, 2006 at 8:01 pmthis is a hassle.
What you can do is burn the audio onto an audio-CD (using itunes or any other application)
and then re-import the audio into FCP.
If that does not work, you need to do serious time-stretching. try the following to see how the quality turns out:
paste the video in a FCP timeline.
Then match the inpoint and outpoint of the video in the canvas en the audio in the viewer (I-O). Then FITFILL the audio into the timeline…good luck
best regards
Jan
managing director
Creative Animal
The Netherlands -
Sergio Deustua
February 8, 2006 at 10:24 amThank you Jan from The Netherlands. The Fit to fill time stretching work out. Thanks a lot.
