Activity › Forums › VEGAS Pro › audio pop/scratch after audio event trim
  • audio pop/scratch after audio event trim
    Posted by Gilles Gagnon on December 10, 2013 at 10:05 pm
    Very odd,
    I resize (trim) the audio event of a video clip. When I play the clip from the beginning, there is a an audible crack/snapple or pop which appears to come in a second or a fraction of a second into the clip.
    I can’t seem to get rid of it. I tried cross fading, fading, etc but I’d have to fade too far into the clip for the crackle to vanish.
    Ay ideas?
    Gilles
    Gilles Gagnon replied 12 years, 9 months ago 3 Members · 7 Replies
  • 7 Replies
  • Steve Rhoden
    December 11, 2013 at 11:54 am
    Have you rendered it and still hear the crack/snapple or pop?
    Steve Rhoden
    (Cow Leader)
    Film Editor & Compositor.
    Filmex Creative Media.
    https://www.facebook.com/FilmexCreativeMedia
    1-876-461-9019
  • Gilles Gagnon
    December 11, 2013 at 11:56 am
    No I haven’t tried that Steve since it is always in the exact location.
    I’ll try this today.
    Thanks.
    Gilles
  • Steve Rhoden
    December 11, 2013 at 12:56 pm
    Do that, because often during intense edits, glitches appear
    in preview, but not in final render.
    Steve Rhoden
    (Cow Leader)
    1-876-461-9019
  • Andrew Lenczycki
    December 11, 2013 at 3:19 pm
    Is the sound crack visible in the audio waveform (you may have to zoom in quite a bit to see it)? If so, I have inserted a Volume Envelope to the track and added points to the left, right and at the crack. Pull down the point at the crack point to “eliminate” it. If this affects your overall sound, you can cut a small section of audio from elsewhere in the event and paste it on the track below to create a “filler” to the lack of audio created by the volume envelope edit. See an example below.
    Andrew Lenczycki
  • Gilles Gagnon
    December 11, 2013 at 3:38 pm
    Thanks Andrew.
    Oddly enough it wasn’t visible, even magnified.
    The good news is that in the export/render, the snap doesn’t exist.
    So… all is well.
    Thanks again.
    Gilles
  • Steve Rhoden
    December 11, 2013 at 4:47 pm
    As i figured Gilles, you’re welcome.
    Steve Rhoden
    (Cow Leader)
    1-876-461-9019
  • Gilles Gagnon
    December 11, 2013 at 5:12 pm
    Yup!
    Thanks again Steve.
    Gilles
