Activity › Forums › Apple Final Cut Pro Legacy › audio pops
audio pops
Posted by Luke Pearson on December 14, 2006 at 2:52 ami’m working on a project and it contains an .aiff audio file. Through out the song there are tiny pops. They are not on the original audio. What causes this and how do i fix it?
Luke Pearson replied 19 years, 9 months ago 4 Members · 4 Replies -
Jeremy Garchow
December 14, 2006 at 3:20 amAre you sure it’s an aiff? What sample and bit rate is the file?
Thaxter Clavemarlton
December 14, 2006 at 4:13 am[JeremyG] “Are you sure it’s an aiff? What sample and bit rate is the file?
“I’d also say that this file is behaving like an mp3 (or other incompatible file-type) in FCP.
I’d convert the file in iTunes.
QT PRO works fine… but iTunes is also a simple ready process after the initial set-up presets:
iTunes > Preferences > Importing > AIFF> Custom > 48.000 kHz, 16 bit, Stereo >OKOnce these are set, you won’t have to set them again.
Put a CD in the Mac (or use a imported audio file that’s already on the HD), open it up in iTunes, click once on the track you need, and choose:
Advanced > Convert Selection to AIFF.Works VERY fast and stores new 48 kHz file in the iTunes library. You can just “drag and drop” this new file (.aif) onto your open FCP Browser.
Luke Pearson
December 14, 2006 at 4:38 amThat worked. Thanks alot.
It said the file that kept messing up was an .aif. the only difference was it had a 44.1 khz sample rate. I changed it to 48 and it worked perfect.
