Activity › Forums › Apple Final Cut Pro Legacy › audio pops on playback
Posted by Ralph Bertini on August 16, 2006 at 5:11 pmCan anyone tell me whats with the audio pops & crackles when playing from the timeline? The audio on the clips is fine. There’s also a “dropout” looking thing in the video from time to time. What gives?
Alan replied 20 years, 1 month ago 5 Members · 6 Replies -
Ben Oliver
August 16, 2006 at 5:19 pmare you using mp3 files??????? everything within fcp has to be 48khz…or 32khz if that’s how your media/timeline is configured.
Ralph Bertini
August 16, 2006 at 7:59 pmThanks for the reply. No, I’m using audio from digitized from mini dv tapes at 48K. I may be crazy but it seems the pops aren’t always at the same place in the timeline.
Steve Ford
August 16, 2006 at 8:08 pmI rember having that problem once. I ended up trashing the pref. files, exporting the files and importing them into a fresh program and the popping went away
Luke David
August 16, 2006 at 8:33 pmyou can try rendering the track or doing a mixdown; apple+option+r. good luck
Alan
August 18, 2006 at 1:01 amalso try throwing away your audio render files. I’ve hada similar problems with my system. I’ll either trash the audio render files or export the audio as an Aiff file and re-import that file back into the timeline. Seems to work most every time.
